I have a drawing that I recieved from a sub. It has almost 4000 annotation scales. A purge does not remove them. How do I remove all these annotation scales? It makes opening the file very slow.
Solved by pendean. Go to Solution.
PURGE does not have a Scales option, look at the pop-up list or the command line list, do you see it listed? Try SCALELISEDIT command (and the command line version -SCALELISTEDIT) have a RESET option to do what you seek:
http://docs.autodesk.com/ACD/2011/ENU/filesACR/WS1a9193826455f5ffa23ce210c4a30acaf-53d4.htm
Hi, I have a drawings with miltiple xref's linked to it. I have to do the commant SCALELISTEDIT on each of the individual xref and the problem goes away (drawing opens faster). However when I close he drawing and reopen i seem to have to do the same exercise again. Is there a way that does this permanently ?
Regards
