AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Recent Documents
3 REPLIES 3
332 Views, 3 Replies
Recent Documents
This refers to AC A2011, when looking at the recent documents in the pull-down, it ONLY shows .dst files. Selecting file types is not the solution...
Tags (1)
3 REPLIES 3
pendean
Do you open files from INSIDE AutoCAD all the time using OPEN command, or do you do so from Windows Explorer (or sheetset manager)?
Inside Autocad.
Volker_C
I just wanted to let you know that this is a known issue. You may want to go into the Options dialog->Open and Save tab. Then clear the Most Recently Used files list. Then relaunch ACA and see if that helps. Unfortunately at this time that is the only suggestion I can offer.
Best regards,
Volker
Please let us know if your questions have been answered by selecting, "Accept as Solution"
Volker C.
SR Technical Support Specialist, KDE
Autodesk Customer Council | Only One AutoCAD | AutoCAD Blog
”Boost
