AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Ram use runaway when sweeping object
0 REPLIES 0
Message 1 of 1
JakeHurzeler
208 Views, 0 Replies
I'm trying to create hoses using the sweep command, just a circle swept along a spline. Every time the command is executed the program just freezes up. Opening the task manager shows that ram usage is ramping up and running away. Anyone else run into this, something like this? Found a fix?
I bought the AutoCAD Revit Architecture Suite 2010 but only installed the AutoCAD 2010 disk.
Running Windows 7, tried all the compatibility modes - no dice
AMD 3.0 ghz quad core
8 gigs pc1066 ram
ATI Firepro 3750
0 REPLIES 0
”Boost
