In our office we have ACA 2013, MEP 2013, Plant 3d 2013 and basic autocad. I want to create a tool palette that can work across all of these platforms. Content browser will work for the first 3, but not basic autocad and I can't simply import a tool palette (xtp file) into the first 3 as there is no option to do so. Does anyone have any suggestions that I could do so that I would only have to maintain 1 file instead of multiple ones?
Thank you,
Mike
You should be able to do this using the application AutoLoader. You can read about it at the link below.
http://adndevblog.typepad.com/autocad/2013/01/autodesk-autoloader-white-paper.html
This link will help also.
http://adndevblog.typepad.com/autocad/2012/04/autoloadertool-palette-support.html
