AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Project synchronize
3 REPLIES 3
334 Views, 3 Replies
Project synchronize
Could someone please explain the synchronize component in project standards.  I am having a problem with my sheet files not displaying the views correctly.  Maybe the synchronize component is not the answer but, I need some assistance in figuring out why my sheets don't display exactly how they are represented in the views.  I am currently working on AutoCAD Architecture 2014 and don't ever remember having this problem in the past.  Any insight on how to resolve this issue would be greatly appreciated.
Justin
3 REPLIES 3
Victoria.Studley
Hi Justin,
I'm sorry to hear you're experiencing an issue with the way your Views display after placing them on a Sheet.
-How are the Views displaying differently on the Sheet than in the View file? (Linetype, extra linework, missing linework, color, etc.)
-Does the issue happen with every View in every Sheet file?
-Does it happen in any other projects, or just one project?
-Was the project created in ACA 2014, or in a previous version?
-Have you checked for file corruption? (Check at the Sheet, View, Construct, and Element levels.)
-If you could upload a screenshot of what you're expecting and another of what you're seeing, that would be helpful in diagnosing the issue.
-Additionally, if you could attach a sample View and Sheet file (or provide a link to the full project in a private message), I'll be happy to take a look.
Victoria Studley
Content Experience Designer - Fusion 360
Fusion 360 | Learn & Support
Documentation | Contact Support
dbroad
Project synchronization is not the complete answer.  Project properties does have a setting that relates to coordination of layers.  There are also problems with transfer of cut plane settings from view to sheet.
Architect, Registered NC, VA, SC, & GA.
in reply to: Victoria.Studley
Thanks for your response but I think I have resolved my issue.  Turns out it was a setting in the sheet template file.  I used an old .dwt file and made the new .dwt match the old one.  Everything seems to work for now.
Thanks again,
Justin
”Boost
