I am running Desktop 2011 x64 on Win7
My project navigator appears to be hidden somewhere. I am able to invoke the command to make it appear but nothing happens.
How can I resolve this?
Have you been able to recover your Project nvigator palette?
Perhaps on another screen? Increase the overall resolution of your screen or rotate the display.
You can try:
1) Click on the button for the command you would like to use
2) Click ALT + Spacebar. Although you cannot see it this is bringing up a menu command on the dialog box
3) Type M for move
4) You have now activated the move command for that dialog box. Use either the left or right arrow key to move the box back into view. This will depend on whether you removed your left or right monitor. Hold down the arrow key and you will see the box come back onto the screen.
If his does not get the palette back you could try a repair from the Windows Control panel. Riight click on your ACA install and select Change/Uninstall. Then follow steps.
