Hi!
I have some problem with a schedule table that I want to present values from a propert set attached to blocks.
The schedule table can´t read any value from the property set...(se attached file)
This is what I have done:
I have tried to select the property set definition to apply to all object without result... so for the moment I have no more suggestions how to solve this...
Anyone that can give some tip?
Solved by David_W_Koch. Go to Solution.
Two things:
1. You are scheduling the Block References, not the (Multi-View Block) Schedule Tags, so the Applies To in your Schedule Table Style needs to be set to Block Reference, not Multi-View Block Reference.
2. The instance of your Schedule Table that you placed in your drawing was set to scan Block References. That means it will look inside the block definition for items to schedule. It appeared to me that you were trying to schedule the main block references, so I changed the "Scan block references" property to No.
See attached.
