I'm using ADT 2012 with FactoryCAD added on and I have one file that for whatever reason it's taking anywhere from 5 to 10 minutes for the print window to even open.
It does work after it's opened and I make my window selection but even that takes longer to process.
It's not a large file, it runs about 7.8 meg in size.
I've done the standard audit and purge to see if it would clear something that was causing a conflict but no difference.
This file has x-refs attached but those same files are attached to other files that have no problem opening the print window.
So I'm looking for some suggestions on what I can try or look for that might be causing this conflict.
Thank you for any help!
