Is it possible to convert an entire project from ACA 2011 to 2008 ACA? By this I mean without opening every drawing.
If you're using AEC objects then there is no way of converting down at all (unles you want to try IFC and good luck with that). You could have a look at the free Trueview or Trueconvert, but I'm not sure if they can batch convert files.
