Hello - I have a client who updated to AutoCAD Arch 2014 and now is having trouble with his grey lines printing pixilated...
He is using the same .ctb file from 2013 (moved up from 2012) also his pc3 file (from 2012).
When he moved to 2013 he had this issue and went back to his 2012 pc3 and everything was working fine again.
So when he had the issue in 2014 he started using the 2012 pc3 file. But this time - no change.
Any Ideas? I am not sure what printer/plotter they are using. He said it is 8 yrs old.
LD
so this is what I know of the printer...
kip 3000
no hdi driver - using standard system driver
windows default converted to pc3.
noticing - using 2014 lines are fuzzy...could be graphics related
images attached both a pdf and a screen shot...
Anyone have any thoughts on this?
I am still stuck...
Thanks -
LD
Thanks for posting this Lisa. Still having this issue. Getting ready to publish a set, but would like to be able to resolve this before I do.
Tried installing the Heidi driver (a couple different versions), but the system wouldn't accept any of them.
Any thoughts?
Thanks.
We use 2014 and have a Kip 3000.
We use HDI drivers - but also, we've upgraded our kip software. We paid to have our Kip people come out to upgrade us to the newest version (7.x). It was relatively inexpensive. Maybe 150 bucks? I can't recall off the top of my head.
We did this for a few reasons. PDF's weren't printing right, and we wanted the new HDI drivers which only were supported with the new 7.x software.
We also did all this prior to upgrading to 2014. If they (or you) are still having issues you might want to try upgrading the KIP system software, and use the new HDI drivers.
Good luck.
