My Autocad Architecture 2014 crashes every time I plot to an HP550 or if I plot to a PDF file.
I am using Windows 8 and a Dell xps 12 g of ram.
Any suggestions?
Hi James,
Crashes with HP printers are usually resolved by updating the printer driver. It's interesting you have the problem on Windows 8 as I would think the driver should be the most current. Is it a Designjet 550 that you have, or a LaserJet? It is a known problem with the Designjet 500 driver not working well with AutoCAD. Have a look at these couple articles:
http://knowledge.autodesk.com/article/AutoCAD-crashes-when-plotting-to-HP-printers
http://knowledge.autodesk.com/article/AutoCAD-crashes-when-you-close-a-drawing-or-exit-the-program
