I am trying to locate Plot Style file. In Option: File: Printer Support File Path I get following directory:
C:\Program Data\Autodesk\ACAD 2011 \ enu\ Plotter\Plot Style.
My problem is: I can not find "Program Data" any where, in "Program files" and by any search I can not see "enu".
It drives me crazy.
I appreciate any help.
Bob
Solved by pendean. Go to Solution.
At the command line inside AutoCAD/ACA type STYLESMANAGER: that folder should pop up in Windows Explorer right in front of your eyes.
BTW: Program Data folder is a hidden system folder in Windows: you get to it by setting Windows Explorer to show them to you using Tools>Folder Options>View tab check boxes.
