AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Osnaps not working on wall components
8 REPLIES 8
Message 1 of 9
stephenmalyszka
927 Views, 8 Replies
Just out of the blue my osnaps will not work on my wall components within a particular drawing (Arch09). The only one that seems to work is along the baseline of the wall. I have had this problem before and the easy way to reslove it was to copy the geometry into a new file. However with this drawing, I will lose all of my layouts and configurations. Any ideas?
8 REPLIES 8
Message 2 of 9
The first thing to check is whether you have the "Allow general object snap settings to act upon wall justification line" toggle checked. (See image, from ACA 2010 - 2009 should have something similar.) When this is checked, object snaps will only work on the justification line of a Wall. Uncheck it to be able to snap to other geometry.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
Message 3 of 9
Yes, it is checked. Not sure if it matters but object snap optimize for speed setting is also unchecked. There must be a setting somewhere that i have missed or the drawing is corrupted.
Message 4 of 9
in reply to: stephenmalyszka
are you referring to plan view or iso/model view?
wrote in message
news:6279507@discussion.autodesk.com...
Message 5 of 9
I might have misunderstood, but I thought David's intention was to make
sure it is *not* checked?
Message 6 of 9
Check layer 0 is not Frozen/Locked/Off.... it usually does the trick!
Eddy Edited by: eddyrichardson on Oct 28, 2009 4:07 PM
Message 7 of 9
A complicated problem is always solved by a simple solution. Thanks Eddy, that did the trick. Now i feel like a fool for not looking at that first.
Message 8 of 9
ok so two more are confirming the bug!
btw it's connected to the layer your material is set on.
change your material layer setting to the object layer (so it doesn;t turn
off) and it won't be a problem.
I don't think this is an acceptable work around at all.
wrote in message
news:6279770@discussion.autodesk.com...
Message 9 of 9
I was having the same problem in one drawing but not another....layer zero was turned off.  Turning it on fixed the osnaps to walls/windows/doors. (phew!)
”Boost
