The first thing to check is whether you have the "Allow general object snap settings to act upon wall justification line" toggle checked. (See image, from ACA 2010 - 2009 should have something similar.) When this is checked, object snaps will only work on the justification line of a Wall. Uncheck it to be able to snap to other geometry.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
