AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Optimization of Windows 7 for ACA
5 REPLIES 5
Tallans422
679 Views, 5 Replies
Hi All,
Is there a consensus or list of settings that should be changed within Windows 7 that will help boost the performance of ACA?  We're switching over to 7 in the next couple months and I want to make sure all settings are adjusted before we install the software.  When I was testing with ACA 2010 I remember movement on the screen being a bit jumpy, some commands were slower as well.
Running ACA 2010
Lenovo S20 Workstation
Intel Xeon W3530 @ 2.80 GHz
6 GB RAM
Todd
5 REPLIES 5
pendean
in reply to: Tallans422
Is ACA2010 even supported in Win7?
Tallans422
pendean
Great, but there are no universal tips: for most there are no issues, for others it comes down to not finding the correct driver (or supported Autodesk driver) for their video card, video settings/color depth, Win7's Aero theme creating havoc (turning it off fixes most issues), and ensuring old 2010 is fully patched and updated (that means everything, not just the main updates).
And system specs in general of course.
Then there are conflicts with other software and running/bckground apps as usual, but those occur with every Windows version.
Holger.Kloecker
in reply to: pendean
We have published some known limitations with AutoCAD 2010 products on Windows 7 here:
http://usa.autodesk.com/getdoc/id=TS14056444
You might consider moving to AutoCAD version 2011 or 2012 when running on Windows 7 since these provide full support.
I hope this helps.
Holger Klöcker
robincapperw
Assume you are going to Windows 7 64? Prime limitation we had with ACA, regarding reliability and performance, was memory consumption. W7 32 wouldn't help that (allocation limits still apply) but 64 bit has elimininted that, until you actually run out of physical memory!
Robin
Autodesk AEC Collection 2020 - PC: HP Z6 | Win 10 64 | Xeon 3014 | 64 GB ram | Quadro P5000 - Tablet: Surface 3 Pro i5-4300u | Win 10 Ent 1703 64 | 8GB ram - Phone: Samsung S21 Ultra | Android 11
RobiNZ CAD Blog | LinkedIn
”Boost
