AutoCAD Architecture General
herudshomes
Message 1 of 10 (390 Views)
Opening End Caps
390 Views, 9 Replies
10-03-2012 04:55 AM
Hi Folks..
this is probebly a realy simple thing, my appologies if so.
I have created a wall, window and endcap that is meant to display a frame (in the wall) all around the window.
The endcap creted perfectly and attached itself to the correct components in the wall. It Looks beautiful BUT the endcap seems to have placed itself on the INTERNAL side of the wall, rather than the External side.
I have included a drawing with what i mean. Is there a way to tell the Endcap to appear on the other side (external Side) of the wall. ?
leothebuilder
Message 2 of 10 (382 Views)
Re: Opening End Caps
10-03-2012 06:40 AM in reply to: herudshomes
Sorry, can't open your drawing, ACA 2012 here
herudshomes
Message 3 of 10 (377 Views)
10-03-2012 08:07 AM in reply to: herudshomes
thanks so much for looking.. ive uploaded a 2010 dwg ;-)
leothebuilder
Message 4 of 10 (371 Views)
10-03-2012 11:31 AM in reply to: herudshomes
If you saved this back from the 2013 version it has exploded everything
herudshomes
Message 5 of 10 (367 Views)
10-03-2012 12:28 PM in reply to: leothebuilder
OK... ive tracked down a computer with 2012 on it with the same result.. I have attached hereto a 2012 make and saved in 2012 ;-)
leothebuilder
Message 6 of 10 (360 Views)
10-03-2012 01:19 PM in reply to: herudshomes
Nothing attached
herudshomes
Message 7 of 10 (356 Views)
10-03-2012 01:48 PM in reply to: leothebuilder
leothebuilder
Message 8 of 10 (346 Views)
10-03-2012 02:32 PM in reply to: herudshomes
I am not 100% sure what you are trying to achieve but from your original post I understand that the 25 x100 popout around the window opening is on the wrong side of the wall.
I changed the opening cap style to be on the otherside by deleting your opening style and creating a new style.
Only problem is that this interferes with the large sill you have on that side of the wall.
You can have this opening cap style to three sides only if you want. (sides and head only)
ACA 2012 file attached
herudshomes
Message 9 of 10 (340 Views)
10-03-2012 03:09 PM in reply to: leothebuilder
Hio leo
thats exatly what i wanted.. The 25x100 sorround to the window.
Im not sure how you created it though.. I see you have created a rectangle 100x25 (adjacent to the wall) and created a new override.
I think i must be creating the endcaps wrong from the polyline? How are you adding the rectangle to the endcap?
Ive tried creting a new ENDCAP STYLE and SET FROM .. Select the rectangle you created and assign to COMPONENT 2, but that didnt seem to work.. ?
Ive obviously missed an important simple step somewhere...
leothebuilder
Message 10 of 10 (336 Views)
10-03-2012 03:42 PM in reply to: herudshomes
I created this as follows"
Right click the wall and select Encap > Edit in Place.
This will prompt you to select a point along the wall.
Select a point close to the window opening.
You'll enter Edit mode.
Draw a rectangle 25 x 100 mm at the edge of the opening.
Select the wall and on the ribbon select Merge.
Merge the rectangle to the wall.
In the ribbon select Finish.
You will be prompted if you want to save this to a new Style. (I named it TEST)
Select Yes and select (tick the box) if you want this as an encap or opening style.
You can also select if you want this to apply to all four sides of opening (or whichever sides)
Select if you want this to apply to all openings or if you want this as an override.
I select override.
Once you have the new opening cap defined, if you now select a wall with an opening you can
override the opening cap and select your new style.
Hope it all makes sense.
You are not logged in.
Ask the Community
