You would like to adjust your SNAP settings within your software.
Solved by MichaelBussiere2. Go to Solution.
In this case you can check the “snap settings” within the “Drafting Settings”. I have made a quick video in the link below illustrating this setting modification.
Video Link (no sound): http://screencast.com/t/gIT8iq6AgWpc
Additionally you can verify the OSMODE with the following settings (also found in your help menu under OSMODE).
Sets running object snaps
The setting is stored as a bitcode using the sum of the following values:
0 = NONe
1 = ENDpoint
2 = MIDpoint
4 = CENter
8 = NODe
16 = QUAdrant
32 = INTersection
64 = INSertion
128 = PERpendicular
256 = TANgent
512 = NEArest
1024 = Clears all object snaps
2048 = APParent Intersection
4096 = EXTension
8192 = PARallel
To specify more than one object snap, enter the sum of their values. For example, entering 3 specifies the Endpoint (bitcode 1) and Midpoint (bitcode 2) object snaps. Entering 16383 specifies all object snaps.
When object snaps are switched off using the Osnap button on the status bar, a bitcode of 16384 (0x4000) is returned, in addition to the normal value of OSMODE. With this additional value, developers can distinguish this mode from Object Snap modes that have been turned off from within the Drafting Settings dialog box. Setting this bit toggles running object snaps off. Setting OSMODE to a value with this bit off toggles running object snaps on.
