OLE objects does not plot in color. The OLE object is in a title block that its being reference to the working drawing. Is the are referencing setting we can manipulate to resolve this issue? Any suggestion?
Doug
Edited by
Discussion_Admin
In this case the raster image is typically having issue with eth driver itself. Please test plotting to PDF using the “DWGtoPDF” driver and not the others from the plot pull down to see if the problem is then resolved. If the issue is not resolved with this test would it be possible to see a sample file for further troubleshooting?
Also does this happen on any other Raster image or isolated to this one image? If isolated to this one image you may need to create new image for attaching to your title block.
