AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Need basic annotative guidance
2 REPLIES 2
jimsullivan2294
181 Views, 2 Replies
Just upgraded from ADT2006 to ACA2008 and am trying to figure out the whole annotative scaling issue. I could really use some basic guidance to get started.
Here's what I used to do- I would have one model file which contained all my drawings which were dimensioned and notated in model space. From there I opened up a new sheets where I x-reffed my drawings in, created viewports and plotted from there.
How do I start setting up for annotative scaling to make it work w/xreffing? Or am I going about this all wrong? If so, can you point me in the right direction?
2 REPLIES 2
in reply to: jimsullivan2294
I'm not sure if you've seen this tutorial or whether it will help you or
not, but, I came across it and thought it might.
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=9493275&linkID=9240615
Good luck!
Melanie Perry
***not all who wander are lost***
http://mistressofthedorkness.blogspot.com
wow! Just what I needed! - Not even my ATC guy knew about
Annotative Object Scale ➤ Add/Delete Scales
They don't work without that!
Thanks!
”Boost
