AutoCAD Architecture General
Member
Message 1 of 5 (324 Views)
My ribbon is in gray and don't function until restart Architecture 2010
324 Views, 4 Replies
03-07-2010 10:28 PM
Frecuently my ribbon is in gray and don't function until restart Architecture 2010. It happen when I'm working, no moore than few minutes, and only my ribbon crash. I can work with command line, and the palettes , but don´t with ribbon.
*Dean Saadallah
Message 2 of 5 (324 Views)
Re: My ribbon is in gray and don't function until restart Architecture 2010
03-08-2010 05:13 AM in reply to: rmendezb
If you type RIBBON, does it come back?
Dean Saadallah
http://LTisACAD.blogspot.com
*Bill Gilliss
Message 3 of 5 (324 Views)
03-08-2010 05:56 AM in reply to: rmendezb
Did you load the old ACA menus? I've had this problem, too. Usually I
can switch to a different workspace and then back.
*MarkB
Message 4 of 5 (324 Views)
03-08-2010 02:52 PM in reply to: rmendezb
Sounds lile acad.cuix is loaded with aca.cuix. When both are loaded, mtext
text command causes the ribbon to grey out. Verify if mtext is causing this,
if so, get rid of acad.cuix.
This is discussed frequently in the newgroup, search for more information.
Mark
"Bill Gilliss" wrote in message
news:6350495@discussion.autodesk.com...
Member
Message 5 of 5 (324 Views)
04-09-2010 10:05 PM in reply to: rmendezb
Thankyou.
Yes mtext is causing the trouble.
i recall workspace and the ribbon is enable again.
You are not logged in.
Ask the Community
