Extra.
My Block has other dynamic behaviour that I would have to construct from scratch if I need to explode block to edit Multiline Attribute. Not ideal, and I already have done it twice, exploding and putting all the behaviour back again.
Autodesk should provide a solution whre we don't need to explode but only lock the position of the attribute inside the BLock.
Ok, I got around my problem for now.
Selected block went into BEDIT, selected Attribute 1, in Properties manager I set Position to Unlock (I was setting it always to Lock as I understood I had to Lock to certain coordinate)
Selected Second ATT and set to Unlock again.
Closed , saved and the Attributes showed in correct place.
