Hi
I'm having issues with mtext... it disappears after I save? This worked for me the other day and printed just fine... now on this same project it shows in model but not in layout! I'm vary new so any help would be great.
Ryan
Hi Ryan,
Welcome to the Forums. For future issues please create a New Message unless you know your problem is exactly like the post you reply to. Also please post in the forum that corresponds to the AutoCAD product you are using.
That being said you issues are likely related to annotative scaling. Make sure you mtext has your viewport scale associated with it. Here is a >link< for you to read up on the subject.
