AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
AutoCAD Architecture 2010 - Monochrome.ctb plot style table missing
21 REPLIES 21
Message 1 of 22
82379 Views, 21 Replies
Has anyone had the problem with the monochrome .ctb plot style table not showing up in the plot dialogue for AutoCAD Architecture 2010? Typically it seems to be standard upon install of the software. Any help is greatly appreciated.
[ The subject line of this post has been edited to include the product name by @handjonathan ]
21 REPLIES 21
Message 2 of 22
David_W_Koch
Are you being offered CTB files as the choice for your plot, and it is just the monochrome.ctb file that is missing?  Is your drawing set up to use color-dependent plot styles?  If not, you will not be offered any CTB files as a choice, only STB files.
Start new files with a template that uses the desired plot style type; use the CONVERTPSTYLES command to change from STB to CTB, if necessary, in an existing file.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
Message 3 of 22
Thank you David, that worked just fine!
Message 4 of 22
in reply to: David_W_Koch
Thank you David, you are my hero !!!
Message 5 of 22
thanks david. definitely solved my problem too!
Message 6 of 22
Great man! Tanks =D
Message 7 of 22
thanks david,
save me lots of time Robot Happy
Message 8 of 22
bonnie529
Thank you David!
I know this thread is a couple years old, but awesome commands and awesome users are forever appreciated Cat Embarassed
Message 9 of 22
I have both the Monochrome.ctb, and the stf, in several files, but autocad lt does not seem to know how to find them, any help would be appreciated.
Message 10 of 22
I also have tried to use the Cute PDF Writer, and it will not allow me to plot in black, along with the monochrome issue, and not being able to convert this drawing into PDF, I am at a loss for options, any help would be appreciated.
Message 11 of 22
David_W_Koch
Do you have the plot style files you want to use in a folder in the Plot Style Table Search Path (Options dialog, Files tab, Printer File Support Path node, Plot Style Table Search Path sub-node)?  In 2014 and later, you can specify multiple folders under this node.  In earlier releases, you are limited to one folder (but you can place a Windows Shortcut in that folder pointing to another folder if you do not want all of your plot styles in that one folder for some reason).
If your drawing cannot find the specified plot style file, then it will default to plotting using the colors defined in the drawing file (definitely true for named plot style files [STB]; may be true for color-dependent plot style files [CTB] as well).
David Koch
Blog | LinkedIn
Message 12 of 22
thank you thats helpful
Message 13 of 22
Thak you! It worked immediately!
Message 14 of 22
mbszameer
Thank u So much....................
        Wish u all the best
Message 15 of 22
bolzteruyui
that helps me a lot..many thanks
Message 16 of 22
excellent. thank You, Mr. KOCH. However, one may have to manually change the color to black in the plot manager setup.
Message 17 of 22
michael6T7C2
C:\Users\Michael\AppData\Roaming\Autodesk\AutoCAD 2019\R23.0\enu\Plotters\Plot Styles
Copy & Paste attachment, should solve the problem
Message 18 of 22
Amazing! Thankyou!
Message 19 of 22
michael6T7C2
Big pleasure! Glad to be able to help!
Message 20 of 22
data9ABBX
thanks, you saved my time 😍
”Boost
