Are ANY ctb's showing in the list? If not, are you sure your drawings is formatted for using ctb's? Check or set in "Options>Plot and Publish>Plot Style table Settings"
Dear All
Hope someone is reading this...
More less same problems as mentioned in the tread
Here running AutoCAD 11 (student version)
Cannot load plot styles to print, and in file/plot stile manager I get sent to my documents...
Of course some path most be wrong, but don't know where, and how to fix it
Does anyone have some ideas to get over this?
They were never gone: a DWG file can either be set to STB or CTB. It won't display the other set if it is set to the one you don't want.
CONVERTPSTYLES switches a DWG file to one of the other as you need it.
