AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Merging Roof Slabs, Is there a way?
2 REPLIES 2
Jason_S
504 Views, 2 Replies
I have a roof that is made out of slabs and was converted to roof slabs to try and fix the strange joint both have given in the design. See Attached.
I tried (or looked) for ways to merge just slabs and couldn't find anything so I converted the slabs to roof slabs and still can't find a way to merge these two slabs that are on the same plane and everything.
Maybe a different approach is necessary.
Any and all help is appreciated also suggestions.
2 REPLIES 2
Libbya
in reply to: Jason_S
A different approach is necessary. Add vertices and pull the edges to where you wan tthem. Then click on the roof and use the "edges" worksheet from the properties palette to get the correct angles/edges.
Andrew
Jason_S
I should have tried that first. Worked great. Thanks for the help.
”Boost
