Solved by pendean. Go to Solution.
You'll need to load the ACAD.CUIx file for the "autocad" menubar if that's what you seek.
Many thanks for great help
I typed MENULOAD command line Clicked browse. Found acad.bak then load and ok
after that i get the menubar
but could you help me where can find (Utilities ) panel in the Ribbon in autocad architecture 2013
in autocad 2013 the Utilities panel at the Ribbon in the home tab
but in autocad architecture 2013 dont know
