AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Mass Elements are now AEC_MASS_ELEMENTS
2 REPLIES 2
347 Views, 2 Replies
I am using ACA 2010-  I opened up my CAD this morning and now when I go to edit a mass element, they now say they are AEC_MASS_ELEMENTS.  In the properties window, I cannot adjust, nor do I even see, width, length, height, ME style options, or anything.  It just gives me "General"  and "3D Visualization" properties.
Did I change a setting, or is it corrupted?  Even if I start a new drawing, or create a new ME, it automatically creates an AEC ME.  Any ideas or help would be much appreciated.
Thank you- Steve Miles
2 REPLIES 2
ntellery
Sounds like it may be a proxy object rather than the original.
Have you saved in 13 and trying to open in 12 perhaps?
10-12 are different format from 13 (-15 presumably).
Any warnings when you first open the file?
Are you starting the program using an Acad shortcut rather than the ACA shortcut (although I assume it opens the extra ACA bits when it senses aec data.
www.ausaca.blogspot.com
Do you know all about the Roof Object? Learn it's secrets
http://ausaca.blogspot.com.au/p/roof-object-video-links.html
in reply to: ntellery
Not sure what happened, but further investigations showed that all of my 3D modeling or smart objects changed to AEC....  Ultimately I linked it to the Microsoft Windows Update that installed the night before.  I set my computer back to a restore point in the previous week and it fixed it.  There were two urgent updates that installed but I did not write them down as to wich one corrupted my ACA.
Thanks for the help!
”Boost
