If you turn off the "Below Cut Plane Body Shrink Wrap" in the display
properties for the slab and move the mask block to 0 elevation it'll
hide. If you need to have the body component turned on you're probably
better off using a masking AEC polygon instead.
John
elina.hyvamaki wrote:
> In the file attached, what should be the elevation of the Mask Block to cover the line of the slab?
