I have create a TAG (Mviewblock with attributes linked to property set data). They work fine, reading the extended entity data that I've attached to hatch patterns, but I would like to add leaders. Ideally the leaders would be smart enough to know their location to feed the data to the TAG attributes so if the leader head changed location the attributes would update. However, I can't even get a simple leader attached to TAG.
I've tried the MLEADER options and can get a leader to attach to a BLOCK but not an MVBLOCK. I keep getting an invalid input error when specifying the block name. Initially it would not accept block names if the BLOCK had attributes but my workaround was to to get the MLEADER linked to the BLOCK then redefine the BLOCK to add the attributes. This however only gives me a BLOCK with attributes not a TAG (MVBLOCK).
Can someone provide me with some guidance to get MLEADERS connected to TAGS (MVBLOCKS)?
Tom
Don't have the time to go in depth today, but take a look at how wall tags are put together. They are inserted with a leader attached.
Here is my drawing where I am trying to put TAGS anchored with MLEADERS. It would be nice to have them connected for ease of use.
Tom
Thanks David-
I did not notice the TAG tool property lists "Leader Dimension Style" not MLEADER style. I was getting frustrated that it would not list the MLEADER style despite the fact it was present in the drawing. I realize now I need to make an "old school" dimension style just for TAG tool leaders.
I think I've got it dialed in now except one thing. As for this exercise I need to but the leaders/tags on varying layers is there a way to specify the current layer as the layer key? If not, I can just reassign them after placing them.
Tom
