When we install Map3D (server license) it rollsback and not complete the install. See error message:
2010/5/19:16:02:17 juanito.canon.csa MXL7390FMTCRWU0 === Setup started on MXL7390FMTCRWU0 by juanito.canon.csa ===
2010/5/19:16:03:44 juanito.canon.csa MXL7390FMTCRWU0 Install Autodesk Design Review 2011 Succeeded
2010/5/19:16:04:40 juanito.canon.csa MXL7390FMTCRWU0 Install DirectX 9.0 Runtime Succeeded
2010/5/19:16:07:03 juanito.canon.csa MXL7390FMTCRWU0 Install Autodesk Material Library 2011 Succeeded
2010/5/19:16:08:25 juanito.canon.csa MXL7390FMTCRWU0 Install Autodesk Material Library 2011 Base Image library Succeeded
2010/5/19:16:15:08 juanito.canon.csa MXL7390FMTCRWU0 Install AutoCAD Map 3D 2011 Succeeded
2010/5/19:16:18:02 juanito.canon.csa MXL7390FMTCRWU0 Install AutoCAD Map 3D 2011 Language Pack Failed Installation aborted, Result=1603
2010/5/19:16:21:57 juanito.canon.csa MXL7390FMTCRWU0 Rollback AutoCAD Map 3D 2011 Succeeded Reboot is required
2010/5/19:16:24:25 juanito.canon.csa MXL7390FMTCRWU0 Rollback Autodesk Material Library 2011 Base Image library Succeeded
2010/5/19:16:26:38 juanito.canon.csa MXL7390FMTCRWU0 Rollback Autodesk Material Library 2011 Succeeded
2010/5/19:16:26:38 juanito.canon.csa MXL7390FMTCRWU0 Rollback DirectX 9.0 Runtime Failed Failure is ignored, Result=1619
2010/5/19:16:27:30 juanito.canon.csa MXL7390FMTCRWU0 Rollback Autodesk Design Review 2011 Succeeded
2010/5/19:16:27:31 juanito.canon.csa MXL7390FMTCRWU0 Install Setup You must restart your system for the configuration changes to take effect. Click Yes to restart now or No if you plan to manually restart later.
2010/5/19:16:27:36 juanito.canon.csa MXL7390FMTCRWU0 === Setup ended ===
Any help is appreciated.
