I am having a problem with my window sills disappearing once I have attached the view to a sheet. The window sills are visible in the constuct and view but once it is attached to a sheet they disappear. Does anyone have any insight on why this is happening?
Justin
Solved by David_W_Koch. Go to Solution.
Hi Justin and welcome to the forums. Below are some thing to check:
Do you use the same template file for the Constructs, Views and Sheets? If not, it is possible that even though the Display Configurations have the same names, the underlying settings may be different. Even if you use the same template file, if someone tweaked the settings in the Construct and/or View files to get the sill lines to display initially, the Sheet files may still have the old settings.
The sledgehammer approach would be to open the View or Construct file that has the desired settings as well as the Sheet file, then open the Display Manager and, in the left sash, drag the Representations by Object folder under the drawing with the correct settings and drop it on the drawing that does not have them. Then do the same for the Sets folder, and finally for the Configurations folder. NOTE: These operations move a lot of data, and, particularly for the Representations by Object folder, you will experience a rather long delay while the data is being read, until you can complete the drag and drop, so be patient and expect to have to hold the left mouse button down for a significant period of time. The other two are a lot quicker.
The surgical approach would be to first determine how you are showing your sills. Are the sill lines flush with the outside faces of the Wall in which the Window is placed, or do they project? If the former, the lines could be the Wall Below Cut Plane component, they could be one of the components in the Sill Plan (or Sill Plan Screened) Display Representation for Windows, or they could be both (you will likely see the Sill Plan component linework on your screen, but if they plot differently that those lines should, it may be the Wall Below Cut Plane component adding its (heavier, out-of-the-box) two cents. Once you know what component is needed, you can check the settings for that component in your Sheet file, to see if the settings match and, if not, make them match.
If different settings in two different templates are the culprit (as opposed to end user editing after the files were created from the templates), then you will want to get the display settings to match between your template files to reduce the likelihood of having to deal with this issue in the future.
I don't think I fully understand the synchronized data. But it probably is the solution to my problem. I am having another issue with my sheet displaying something different than the view, once the view is placed on a sheet. If you have any more insight I am all ears.
Justin
In your previous posts, you use the terminology (construct, view, sheet) of the Drawing Management feature (Project Browser and Project Navigator). Assuming that you are using the Drawing Management feature, you can, as VitalyF pointed out, take advantage of the Project Standards feature that is part of the Drawing Management feature to establish a standards file for Display settings and then synchronizing all of your project files with that Standards file. That would save the bother of manually updating each errant drawing file using the method that I had suggested.
At some point, you will want to get all of your template files to have the same Display settings as the standards file. That way, newly created drawings are already in compliance, and the only thing you would have to use the Project Standards synchronization for is if, for a given project, you decide to make revision(s) to the settings established in the template files.
The online Help has a large section devoted to Project Standards. If you are interested in pursuing this, I suggest that you start by reading through the material there.
As David pointed out if you are using the Drawing Management Feature then you can use the project Standards. I thought I would just reiterate this and say that if you do NOT use the Drawing Management Feature (and alot of firms do not) then the project Standards synchronization feature is not available.
