My drawing will only allow 3 viewports in each paperspace layout created. When I try to add or copy more than 3 viewports previous viewports created will go blank and cannot be activated anymore. I have never had this issue before, is there a setting that can fix this problem? I am running AutoCAD Architecture 2010
Solved by pendean. Go to Solution.
