Create a Display Configuration for each plan type you use (First Floor,
Second Floor, Foundation, Framing, etc.) and change the Display
Properties of your AEC objects per these Display Configurations.
Perhaps someone will post some helpful information as to how you would
go about doing that, since it takes awhile to wrap one's head around the
concept and procedure, but this is the direction you will want to go
with it.
mikeshick wrote:
> What would be the best way for showing the floor plan above on a framing plan, such that the walls are faded back with dashes, but the walls of the floor below remain solid with darking lines?
> Thanks.
