1) Use pedit to convert the outline to a polyline.
2) Use membershape to add the new structural shape and use the "create
style" button to convert the shape to a member style.
3) Then use columnadd to add the column.
wrote in message news:6387400@discussion.autodesk.com...
I'm trying to create a column as in the attached drawing. Trying to use
column-> apply properties to linework, does not work as a column. How does
this command work so as to create the attached irregular shaped column.
Thanks for the help.
