AutoCAD Architecture General
Distinguished Contributor
BBP-Arch
Message 1 of 4 (133 Views)
In-Place Clean-up Edit
133 Views, 3 Replies
10-16-2012 02:03 PM
Hi-
I've recently discovered In-Place Clean-up Edit and it has changed my life. Why didn't anyone tell me about this before? Weird wall clean-ups that don't work are a thing of the past...yeee-haw!
However...
For some reason, I can't get out of edit mode...I'm stuck in it right now. Once done w/ all the editing of the wall clean-ups, there is no way to end the command! I thought that there was a 'finish' icon that appeared on the ribbon during the editing of a clean-up in-place....
Is this weird? Have I inadvertantly altered a setvar?
Scott
*Expert Elite*
Message 2 of 4 (125 Views)
Re: In-Place Clean-up Edit
10-16-2012 07:23 PM in reply to: BBP-Arch
When entering in-place edit mode, you should have gotten the Edit in Place:  Wall Cleanup ribbon tab, which has an Edits panel with Cancel and Finish tools to end the in-place edit mode, either by abandoning or saving (respectively) the changes you made.
The Finish tool runs the AecInplaceEditSaveAll command.  The Cancel tool runs the AecInplaceEditDiscard command.  You should be able to type one of those at the Command prompt to exit in-place edit mode.
David Koch
BBP-Arch
Message 3 of 4 (112 Views)
10-17-2012 08:37 AM in reply to: David_W._Koch
David-
You're exactly right, I SHOULD have gotten the "Edit in Place:  Wall Cleanup ribbon tab", but it doesn't appear. That, I believe, is the crux of my problem. How do I get that ribbon to appear?
*Expert Elite*
Message 4 of 4 (105 Views)
10-17-2012 04:50 PM in reply to: BBP-Arch
If you are using an out-of-the-box ACA.cuix file (or a customized version based on that), you should get that contextual ribbon tab automatically, if you are a relatively recent release.  What version of ACA are you using?  If you are cleaning up Walls in place, I assume you are not running ACA as AutoCAD, or are otherwise using the ACAD.cuix file, and you have not disabled the ribbon or disabled contextual ribbon tabs.
David Koch
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
