As today I accidentally moved my autocad architecture folders, some functions were not working properly and I deleted all of them which took me a long long time!
and I reinstalled autcad architecture 2011. Surprisingly when everything works fine, the loading scene says that it's autocad architecture even, I have a unusual welcome page and when I take a close look at it, it's not autocad architecture anymore but autocad 2011!!!!!!
Has this ever happend to anyone before??????????????????????????????? I'm just curious
AutoCAD Architecture, if selected, will install two profiles: one as Architecture and one "as AutoCAD".
Appears you are running the other profile: OPTIONS command>Porifles tab>confirm that is the case.
Yeah but when I installed it, it only sais autocad architecture 2011 + design review things + material library.
There was no autocad at all.
What funny is that when I open the it, it still says that im opening autocad architecture but the actual program is autocad, and when I click the menu on the left tp corner, the Big A, next to the option there says exit autocad architecture instead of autocad.
And I couldnt find any autocad architecture on my harddrive.
It's in the name ~
AutoCAD Architecture >> it's AutoCAD plus Architectural abilities.
I wrote 'profiles', ACA can install two of these, and I suggested you examine the PROFILES in OPTIONS command: did you? What did you find? How many? What are they called?
