I use the 2012 version, here are my problems:
1.If I try to change the color of a layer,the 2012 automatically creates a new layer called "unsaved",why is that?
2.Why whenever I create a new layer with 2012,the objects from another layer automatically joins this layer?
3.How can I shade one single object only?I use 2012,but it always shades the entire drawing,even if I selected only one object.
Solved by SerenneCam. Go to Solution.
Okay,I solved the first problem.
Can I have different objects to be in different layers?I create an object in one layer,how do I make it stay in that layer when I make a new layer or switch layers?
You said I cannot shade one object only, then how do I set different objects in different colors? When I see architect's draft, they always have different colors for different things.I assume I can separate colors by layers, but as mentioned, I have problems putting objects in different layers.
I click on "create new layer", give it a name and a color, then save.
I set the layer I created to be the current layer, my object now is the color of the layer.
When I create another layer with another color, it is automatically set to current, and my object changes to the color of this new layer.
I don't think anything is wrong with my software anymore, but how do I make an object stay in one layer without travelling to the next?
I screenshot a video of what I did, can you check if it's right? It still doesn't work for me.
Can you tell me your email, because the attachment does not support video file or rar file. If you don't want to publicize your email, just send a random email to mine 1342503321@qq.com
