1. Please advise or provide a link to a good brief and readable article on instructions of how to "Publish" a set of drawing fromw the layouts in version 2014. (are these binded PDFs?)
2. The same instructions work with version 2015?
3. The instructions are similar for vanilla AutoCAD?
3. Are final outputs PDFs?
Thanks in advance.
Solved by Victoria.Studley. Go to Solution.
PUBLISH command and function hasn't changed in 15-years: there are hundreds or blogs, tutorials and YouTube videos explaining usage. Use your favorite web search engine and explore.
Hi Octavio,
Here are some links that will help you familiarize yourself with the publishing options in AutoCAD Architecture:
Commands For Publishing Settings
To Work With Publishing Options
About Publishing Drawings to PDF
If you are using Sheet Sets, the following might also be of interest to you:
To Modify a Sheet Set for Publishing Using the Publish Dialog Box
