AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Help with layering on Auto CAD 2014
2 REPLIES 2
pcfd2235
258 Views, 2 Replies
This is probably an easy fix and I have no clue what I messed with but when I draw a line or any object, no matter what layer I have it set on, it will display as yellow instead of "by layer". Any help is appreciated.
2 REPLIES 2
David_W_Koch
in reply to: pcfd2235
With no item selected, on the Properties palette, on the Design tab, set the Color property to ByLayer.
-OR-
Type COLOR at the Command: prompt and press ENTER.  In the Select Color dialog, choose ByLayer (button on the right side, just below the dialog center.
You must have changed the default color for new objects from ByLayer to Yellow.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
pcfd2235
in reply to: David_W_Koch
David,
Thanks! I spent a whole day not realizing that. It's always the little
things that will get ya. Thanks again for your help!
William Koerner
Estimator
New Picture (1)
NOTICE
The information contained in this communication, including attachments is
privileged and confidential . It is intened only for the exclusive use of
the addressee. If the reader of the message is not the intended recipient,
or the employee of agent responsible for delivering it to the intended
recipient, you are hereby notified that any dissemination, distribution or
copying of this communication is strictly prohibited. If you have received
this communication in error, please notify us immediately.
”Boost
