How do I reinstall my ACA 2013?
Do I have to uninstall from my control panel?
When I put the disc in I have no options to fix, reinstall or uninstall?
My problem is that I did not want all the metric mumble jumbo so I unchecked it. Big mistake because I’m missing a lot of content and it still installed every template as metric.
I Also don’t understand the “Global vs. Imperial”??
Solved by leothebuilder. Go to Solution.
Via control panel, select "Programs and Features", hightlight the ACA program, right click and select " Uninstall?Change", follow the prompts and select "Repair Installation"
Thanks, just did a full install. Works fine now, everything loads correctly
