AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Ground level slab
1 REPLY 1
xikigha
1019 Views, 1 Reply
Ground level slab
I am new to ACA. I am currently working on 3D model of a 2bedroom bungalow. In it I have a Porch, Living room, Dinning room, Kitcchen, two bedrooms, toilet. The problem I have is how to create the slab to show the Porch at 750mm, living room at 450mm, Dinning room at 750mm & bedrooms at 600mm? All on ground floor level. Also so it shows properly on section view. Help me plz cos there are no video tutorials on this.
1 REPLY 1
danellis2982
in reply to: xikigha
Any reason why you can't draw them as separate slabs and give them appropriate elevations (using the TOP or BOTTOM values, depending on how your slab style's defined).
The trick will be selecting a suitable CUT PLANE.  A value of 1800-2100 would equate to 1350-1650 in the dining room and bedrooms and 1050-1350 which *should* work for both levels.
dJE
”Boost
