First thing I will admit, this is on a laptop with the card: AMD(ATI) FirePro M8900(FireGL)Mobility Pro Graphics, which ain't sanctioned by Autodesk anymore.
But, this "fading" issue only happens in 2014 ACA(and AMEP). Doesn't happen in Plant3D2014, vanilla Acad2014, AcadE2014, nor AcadM2014. I do not have any locked layers nor do I have any xrefs.
Example scenarios: roll my mouse wheel, it will fade each click, but then settle unfaded. If i pan, it will stay faded until I roll the mouse wheel, or double-click the wheel. Just typing in REGEN or REGENALL doesn't remove the fade either.
Anyone have an idea if there is a setting I could change that may resolve this? BTW, I know the card isn't sanctioned, but I can't change the card out.
Solved by dennis. Go to Solution.
Well....weird one. I kept messing with settings. Turned off hardware accl, but the problem persisted. I then turned hardware accl back on, thinking that it didn't make a difference....the problem went away.
