AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Fatal Error Autocad Architecture 2010 at startup
1 REPLY 1
bgempp
439 Views, 1 Reply
Hi All ~
I have been getting fatal errors during my user account but not in my admin account.  I logged in as admin and repaired Autocad Architecture 2010, using the system disk.  I got back the report that Autocad was repaired.  However, when I returned to my user account, I get an unhandled expection error when I start up Autocad.Architecture 2010.  Do I need to uninstall Autocad Architecture 2010 and then reinstall or should I just pick the option to reinstall Autocad Architecture and then do I have to another registration code??  I really need to get this fixed so I can continue to work.
Email: bgempp@umassd.edu
Thanks to all for your time and consideration in this matter.
1 REPLY 1
pendean
in reply to: bgempp
Run 2010 once as full admin, then try again with the knocked down credentials.
”Boost
