AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
FATAL ERROR: Duplicated Service Name: SERVICE_VBA
1 REPLY 1
randy.thompson
1663 Views, 1 Reply
My staff is starting to get the following fatal error when opening AutoCAD ACA 2010:
We think taht this is happening after oening a session of AutoDesk Impression and then closing the Impression session and starting AutoCAD. We have corrected this by deleting the username directory under the C:\documents & Settings directory.  Obviously we wuold like to fix the problem without using this work around.  Any idease would be greatly appreciated.
Thank You,
Randy Thompson, President
AgeWave Solutions, Inc.®
340 Heald Way, Suite 224
The Villages, Florida 32163
Phone: (352)-391-9669
Facsimile: (352)-391-9668
Randy.Thompson@AgeWaveSolutions.com
1 REPLY 1
in reply to: randy.thompson
Uninstall the AutoCAD VBA Enabler should solved the problem.
I am getting the same error when I downloaded and update the VBA Enabler for my AutoCAD Architecture 2010. Unfortunately have to uninstall it in order to run ACAD. Hopefully Autodesk will find the solution as I need to run the ACAD with VBA enabled. Man Sad
”Boost
