AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Express Tools gone
2 REPLIES 2
leothebuilder
513 Views, 2 Replies
Express Tools gone
This is frustrating.
Downloaded the (subsciption based) RPC plugin. All works fine and it appeared on the (wonderful!!!) ribbon.
Problem is....Express Tools are gone from the (Most wonderful!!!!) ribbon.
For years all you had to do is type "expresstools" at the command prompt.
No more....unknown command.
Press F1 for the (Really wonderful!!!) online help.
This tells me to enter "expresstools" on the command line.
Or try "expressmenu" on the command line.
Probably old leftovers suggestions from 2008 or so.....
We spent sooooo much time on the (freakin' unbelievable wonderful!!!) ribbon that we didn't have time to update the (not going to repeat) Help file.
One step forward....two or even three steps back.
Just venting here a little.................been at it all day................but any suggestions are welcome.
2 REPLIES 2
pendean
in reply to: leothebuilder
If you got 'unknown command" then ET is no longer installed: pop that application DVD in and reinstall it, it's found under the custom installation procedure and is NEVER installed alone if you did not actively seek it.
Yup...re-install seems the way to go....thx
”Boost
