There are several base cabinets that I have been trying to use in a generic house plan that I have pulled from the catalog. For some reason, the cabinets are in an exploded view and will not return to the normal view. No matter what I do, I cannot get them back to their original configuration. Please help!
when you reply, there is an Attachments segment below were you type words and a browse button: use that to post the block you found online.
or just provide a link from where you got it.
I should have tried this first and I apologize for the inconvenience. The problem was not with the block itself, it was somehow conflicting with my particular document. I copied and pasted everything into a new document and the new document allowed cabinets to be placed without exploding them. I still don't have a clue as to WHY it happened, but it did. I will follow up if it happens again.
