AutoCAD Architecture Forum
Welcome to Autodeskā€™s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
Exploded Cabinets
4 REPLIES 4
sarbear.94
578 Views, 4 Replies
Exploded Cabinets
There are several base cabinets that I have been trying to use in a generic house plan that I have pulled from the catalog. For some reason, the cabinets are in an exploded view and will not return to the normal view. No matter what I do, I cannot get them back to their original configuration. Please help!
4 REPLIES 4
pendean
in reply to: sarbear.94
post the block.
sarbear.94
How would I post the block? I am a student and I'm learning as I go, so please bear with me.
pendean
when you reply, there is an Attachments segment below were you type words and a browse button: use that to post the block you found online.
or just provide a link from where you got it.
sarbear.94
I should have tried this first and I apologize for the inconvenience. The problem was not with the block itself, it was somehow conflicting with my particular document. I copied and pasted everything into a new document and the new document allowed cabinets to be placed without exploding them. I still don't have a clue as to WHY it happened, but it did. I will follow up if it happens again.
ā€Boost
