when i start up Autodesk AutoCAD Architecture 2010 or 2011 (I tried both versions) I get the error message:
acad.exe - Application error
The application could not be started correctly (0xc0150002)
I searched the internet without any luck, many people have this problem with other programs, but nobody has a solution!
The funny thing is, it worked (2010) then suddenly it stopped working... I uninstalled and reinstalled 2010, didn't work, then I thought lets try the newest version, exactly the same error! 😞 Other programs work properly, also other Autodesk programs like Inventor 2008.
Thanks for help
PS:
Windows 7 Enterprise 64Bit
Windows is up to date
AutoCAD Architecture is up to date (SP1)
Installed the newest Graphic Driver
"suddenly" means you changed something on your PC: just get Norton products updates (or new)? Add or delete, or had a hiccup in Windows?
"suddenly" means from one day to another. maybe a windows update?
there are no norton products installed, i use "microsoft security essentials" and also scanned my pc with other products like stinger/hijackthis/spybot, computer is clean.
i also looked in the programs-windows and uninstalled every program since it doesnt work, after a reboot, didnt help
"please dont help so much !"
We help where we can, but comments like that won't endear you to anyone. This is a forum, not tech support.
If you are on subscription contact your reseller for help.
