Highlight the problem line and look at the Start "Z"and End "Z" values in
the Properties palette. They are probably different, so you can change both
to "0" if that is the desired elevation. That just takes care of that line
and doesn't address the real problem.
Are you snapping to an endpoint when picking the first endpoint of the new
line? If you are, it is probably grabbing the "Z" elevation of that picked
point to start the new line. If your current elevation is set to "0", then
your 2nd point (that you are specifying with a specific "X" or "Y" distance)
will have a "Z" elevation of "0". That means that you have a sloping line
which looks fine in plan plan, but won't if you look at it in an elevation
view.
Autodesk has added a variable named "OSNAPZ" which helps with this. If you
type "OSNAPZ" and set it to "1", when you snap to an existing endpoint, it
ignores the "Z" value of the point to which you are snapping and uses the
current "Z" elevation. It basically eliminates the problem which it sounds
like you are seeing. There is also a little icon toggle for this setting at
the lower right corner of your status bar, just to the right of the
Elevation setting. (Note that this elevation setting is what is being used
for the "Z" coordinates for any point not specifyng the Z" value.)
Existing "Z" values are not changed when using "OSNAPZ", but it helps keep
the problem from happening with new points as long as you keep that value
saved.
Also note that you may not think that you are drawing in 3D, but I have seen
a lot of blocks created with 3D points even though there seemed to be
nothing 3D about them. When those blocks are used, then the above problems
result.
I hope that takes care of your issue.
Doug
www.dougbowersconsulting.com
blog: http://aectechtalk.wordpress.com
"m_blaine" wrote in message news:6285091@discussion.autodesk.com...
I'm drawing in 2d, absolutely nothing is in 3d. Sometimes i'll draw a line
and use a numerical value to tell the line how long to go. Let's say 52mm.
Then i took a distance of that line and it tells me the distance is
something like 1275.3854 but the Delta X is 52mm. It looks to me like the
line is being drawn on a different axis i can't see. I would rotate the
drawing to check but it's a very large file and freezes when i do so. Why
would the line be drawn on a seperate axis? Is there something i can do to
fix this?
Thanks.
