AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Double Swing Doors
6 REPLIES 6
DDING
3952 Views, 6 Replies
Double Swing Doors
Greetings,
Having just recently switched employers I'm trying to get some "old" styles back . One of those was a door showing a double swing. I've never had the need to customize but am in a situation now where I will need to start doing so. It seems as though showing a door with a double swing would be an easy task but I'm not even sure how to start.
Are there any simple tutorials or any suggestions were to begin?
6 REPLIES 6
David_W_Koch
in reply to: DDING
I would suggest using a custom display block to add the dashed representation of the door swing.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
ntellery
in reply to: DDING
A very easy cheat way to do this is simply add another door over the top. Quick and dirty if it's just a one off.  Just make sure it doesn;t get scheduled.
www.ausaca.blogspot.com
Do you know all about the Roof Object? Learn it's secrets
http://ausaca.blogspot.com.au/p/roof-object-video-links.html
croc49
in reply to: DDING
If you mean "double swing" to be say opening 90 degrees forward and back, you can nominate a predefined one in design rules - communicating door.
Change opening % if you want to open more than 90 degrees.
DDING
in reply to: croc49
The communicating style is the closest to what I need, now the next problem is for a double door.
croc49
in reply to: DDING
Double dhung will work, although you'll probably have to compromise hidden lines.
DDING
in reply to: croc49
Thanks, that's what I was looking for. I can live without the hidden lines.
”Boost
